Displays the DHCP server's configuration for the specified VLAN.
| vlan_name | Specifies the VLAN of the DHCP server of interest. |
N/A.
None.
The following sample output displays the configuration of the DHCP server for the VLAN test:
#show vlan test dhcp-config DHCP Address Range : 10.10.10.100->10.10.10.200 Netlogin Lease Timer : Not configured (Default = 10 seconds) DHCP Lease Timer : Not configured (Default = 7200 seconds) Primary DNS Server : 1.1.1.1 Secondary DNS Server : 2.2.2.2 Ports DHCP Enabled : 23
This command was first available in ExtremeXOS 11.0.
The output is modified to show primary and secondary DNS servers in ExtremeXOS 12.1.
